I’ve put together an automation that works sometimes, but more often, it does not.
Here’s what I’m trying to do:
I have an IR distance sensor attached to my garage door opener that measures the distance to the next object downwards. Based on that information I set the status to either ‘Car in Garage’ or ‘Garage Empty’ for sensor.garage_status
When the status of that sensor changes, I store the date and time of the change in a helper called input_datetime.garage_status_last_change
I want a smart switch to turn off the garage light when I remove the car from the garage and (within 45 seconds) close the garage door.
This is how I’m trying to achieve this:
alias: Garage Lights Off when Car Removed and Door Closes
description: ""
- platform: state
entity_id:
- cover.garage_door
to: closed
condition:
- condition: template
value_template: >
{{ as_timestamp(now()) - as_timestamp(states('input_datetime.garage_status_last_change')) < 45}}
- condition: state
entity_id: sensor.garage_status
state: Garage Empty
- service: switch.turn_off
data: {}
entity_id: switch.garageswitch_1
mode: single
Sometimes the light turns off, but more often than not it doesn’t.
In the failing cases the trace shows that the templated time condition {{ as_timestamp(now()) - as_timestamp(states('input_datetime.garage_status_last_change')) < 45}}
is showing up as ‘false’.
Do I need to build the condition differently or is that just not a reliable way to do it at all?
