Unstable Status "Unavailable" - Shelly UniPlus - starting with HA 2024.7.0 Update
Hi everybody :slight_smile: ,
since the HA update to 2024.7.0 I am experiencing different behaviour in both of my Shelly PlusUni devices. This results in problems with my automations.
Starting with the HA upgrade, the entities of the devices show in most of the times “unavailable”. Only in the moment the device reports its status data, the HA status switches shortly to the reported value but instantly switches back to “unavailable” again.
Before the HA update, the entity status was kept stable until the entity itself changed its status. See Screenshot - behaviour after the update is in red rectangle.
Can anybody confirm having this behavour as well?
Or do you have a hint, what to change to set it back to the behaviour I had before?
  • I am using HA 2024.7.0 since 3.7.24
  • HA Installation is in a docker container on a x86-64 device.
  • Shelly Firmware (v1.3.3) did not change in this time period.
  • HA binding of Shelly PlusUni as described in [Shelly - Home Assistant] - " Shelly device configuration (generation 2 and 3)" - Outbound WebSocket
Thanks an regards,
Mike
In the log I see error messages like this:
2024-07-05 17:00:47.365 ERROR (MainThread) [homeassistant.components.shelly] Unexpected error fetching PlusUni-Garage data
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 312, in _async_refresh
self.data = await self._async_update_data()
File “/usr/src/homeassistant/homeassistant/components/shelly/coordinator.py”, line 594, in _async_update_data
if not await self._async_device_connect_task():
File “/usr/src/homeassistant/homeassistant/components/shelly/coordinator.py”, line 167, in _async_device_connect_task
await self.device.initialize()
File “/usr/local/lib/python3.12/site-packages/aioshelly/rpc_device/device.py”, line 208, in initialize
self._update_listener(self, RpcUpdateType.INITIALIZED)
File “/usr/src/homeassistant/homeassistant/components/shelly/coordinator.py”, line 680, in _async_handle_update
self.async_set_updated_data(None)
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 447, in async_set_updated_data
self.async_update_listeners()
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 165, in async_update_listeners
update_callback()
File “/usr/src/homeassistant/homeassistant/components/shelly/entity.py”, line 372, in _update_callback
self.async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1007, in async_write_ha_state
self._async_write_ha_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1133, in _async_write_ha_state
state, attr, capabilities, shadowed_attr = self.__async_calculate_state()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1068, in __async_calculate_state
state = self._stringify_state(available)
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1013, in _stringify_state
if (state := self.state) is None:
File “/usr/src/homeassistant/homeassistant/components/sensor/init.py”, line 533, in state
value = self.native_value
File “/usr/src/homeassistant/homeassistant/components/shelly/sensor.py”, line 1097, in native_value
return self.attribute_value
File “/usr/src/homeassistant/homeassistant/components/shelly/entity.py”, line 519, in attribute_value
self._last_value = self.entity_description.value(
File “/usr/src/homeassistant/homeassistant/components/shelly/sensor.py”, line 998, in
value=lambda status, _: status["freq"],
KeyError: ‘freq’
Similar issue reported here. Looks like a fix is planned.
Should be fixed in 2024.7.1
Thanks für the link!
I upgraded to 2024.7.1 and the error is gone :+1:
Thanks to the HA team for the quick reaction!
Regards, Mike
