Untracked Energy from where?
I have this entity but really don’t know from where it’s created and which integration is using it.
If i try to have infos i get this window:
It says it’s not available. but i can see it’s consuming power…
you can enable it in the settings?
if you click the Sankey element, what entity_id does to show?
maybe its not even the same entity_id
No, i cannot do nothing with that entity as i cannot see in the total entities, it’s not visible also in devices, i can see it only in the flow card and in individual use of single devices:
like ‘Consumi non monitorati’
It has no unique id
It’s not an entity, it’s just a graphical representation of the amount of energy consumed that you haven’t got a device to attribute to.
Whichever card you clicked that launched that more-info window has a bug, it shouldn’t attempt to open a more-info window as it’s not a real entity and there’s nothing to display.
Ok, but this graphical representation is visible also if its value is zero?
Raise an issue with the card developer. I don’t know what that is, assume it’s something custom.
Yes, i see its already done…
The card is energy-sankey card…
BTW thanks for the clarification…
It’s as I already stated in the other topic…frontend doing its thing :wink:
Agreed. I’ve now fixed that for the upcoming v0.0.20
