Update 2025-12 Boot failure
Since updating to 2025-12 and 2025-12-1 when the Raspberry Pi 5 reboots HA does not start, I have to power off and on again.
The pi comes back up quickly and I can ping it but I still cannot get to homeassistant.local::8123 until I restart the pi.
Anyone else seeing this issue?
  • Installation method: Home Assistant OS
  • Core2025.12.1
  • Supervisor: 2025.12.2
  • Operating System:16.3
  • Frontend: 20251203.1
homeassistant.local:8123
Until you restart the Pi? So, you restart the Pi and can connect to homeassistant.local:8123 ? Then, what’s the issue?
If you have an issue that you haven’t explained, what does the terminal on the Pi say?
The issue is I have to turn the power off the pi then back on otherwise I cannot get into homeassistant
Yes this is exactly my issue also!
Since 2025.12 when I need to restart my home assistant (due to app update for example) my system fails to start and I have to turn off and on the power on my raspberry pi 4 in order to make it work again!
Häng ich mich auch mal ran. Total nervig. Der Fehler.
mwuerzburger: How to help us help you - or How to ask a good question
