UPDATE:
In the end my Home Assistant is working again.
I first got the restored backup working by running the command ha core restart.
Then I tried runnign my original instance of home assistant again.
It did shows some errors (see below), but I saw the logs of supervisor and core were still busy doing things and in the end it loaded fine.
2025-03-09 14:44:45.380 ERROR (MainThread) [supervisor.homeassistant.core] No Home Assistant Core response, assuming a fatal startup error
2025-03-09 14:44:45.381 ERROR (MainThread) [supervisor.core] Can’t start Home Assistant Core - rebuiling
2025-03-09 14:44:45.396 INFO (SyncWorker_5) [supervisor.docker.manager] Stopping homeassistant application
2025-03-09 14:45:05.010 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning homeassistant application
2025-03-09 14:45:14.254 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from a0d7b954_adguard
2025-03-09 14:45:14.369 INFO (MainThread) [supervisor.api.middleware.security] /network/interface/enp0s3/info access from a0d7b954_adguard
2025-03-09 14:45:28.482 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Samba share to start, took more than 120 seconds
2025-03-09 14:45:54.225 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2025-03-09 14:46:17.459 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant Package qemux86-64-homeassistant · GitHub with version 2025.2.4
2025-03-09 14:46:17.460 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-03-09 14:49:18.153 ERROR (MainThread) [supervisor.homeassistant.core] No Home Assistant Core response, assuming a fatal startup error
2025-03-09 14:49:18.154 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_repair - core / None
2025-03-09 14:49:18.155 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - core / None
2025-03-09 14:49:18.156 INFO (MainThread) [supervisor.addons.manager] Phase ‘application’ starting 7 add-ons
OLD POST:
@DeFla, @jonslilbro , @Rene6
Have you been able to solve this issue?
I am facing the same problem “No Home Assistant Core response, assuming a fatal startup error”
I was thinking I’d fix it by doing a clean install and then restoring my backup from a few days ago, but the restoring backup page keeps running eternally, and when I SSH into my Home Assistant and check type ha su logs then I see the restore process fails due to the same error:
2025-03-09 13:08:24.544 ERROR (MainThread) [supervisor.homeassistant.core] No Home Assistant Core response, assuming a fatal startup error
2025-03-09 13:08:36.557 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name=‘Task-824’ coro=<BackupManager.do_restore_partial() done, defined at /usr/src/supervisor/supervisor/jobs/decorator.py:191> exception=HomeAssistantStartupTimeout(‘No Home Assistant Core response, assuming a fatal startup error’)>
File “/usr/src/supervisor/supervisor/jobs/decorator.py”, line 312, in wrapper
raise err
File “/usr/src/supervisor/supervisor/jobs/decorator.py”, line 304, in wrapper
return await self._method(obj, *args, **kwargs)
File “/usr/src/supervisor/supervisor/backups/manager.py”, line 884, in do_restore_partial
success = await self._do_restore(
…<6 lines>…
File “/usr/src/supervisor/supervisor/backups/manager.py”, line 742, in _do_restore
await self.sys_homeassistant.core.start(
_job_override__cleanup=False
raise err
File “/usr/src/supervisor/supervisor/homeassistant/core.py”, line 352, in start
await self._block_till_run(self.sys_homeassistant.version)
File “/usr/src/supervisor/supervisor/homeassistant/core.py”, line 509, in _block_till_run
raise HomeAssistantStartupTimeout(
…<2 lines>…
supervisor.exceptions.HomeAssistantStartupTimeout: No Home Assistant Core response, assuming a fatal startup error
So now I’m equally lost as you are (were?)
Any help would be greatly appreciated. I rely on Home Assistant for a great many things (even my password manager…)
