Zoneminder 1.33 does not authenticate with HA when OPT_USE_AUTH is on. It works if turned off. Apparently the authentication in Zoneminder has changed.
I have the same or similar issue. I’m able to log into ZM and I can see the events increasing. However I’m unable to stream any camera, even when using the “admin” account. ZM log shows “Unable to authenticate user” as Error and the “Unable to authenticate user admin” as Warning
It works when OPT_USE_AUTH is not checked.
Is there something I missed?
I just found the solution for my issue. In zoneminder Options–> system the value for AUTH_RELAY
should be “none”.
