I have used the following code to show the current and available versions of Hass as sensors and those work. However, the sensor Update Available which I have commented out only ever shows no. This is even when I go to the Hass panel and advanced tools and it shows I am on an old version.
Apparently, this script was made for the old RPi all-in-one.
How do I need to change the commented out lines to say Yes if there is an update available and No if there isn’t?
# Version and Availability - platform: rest name: "HASS Current Version" resource: https://pypi.python.org/pypi/homeassistant/json value_template: '{{ value_json.info.version }}' scan_interval: 3600 - platform: command_line name: "HASS Installed version" command: "head -5 /config/.HA_VERSION" # - platform: template # sensors: # hass_update_available: # friendly_name: "Update Available" # value_template: >- # {%- if states.hass_current_version.state != states.hass_installed_version.state -%} # {{ states.hass_current_version.state }} # {%- else -%} # No # {%- endif -%}
