Battery Cell Card - Real-Time Battery Cell Monitoring
Version: 0.9.3
Description: A custom Home Assistant card for visualizing battery cells, cell voltages, SOC, balancing status, and voltage differences etc.
Ideal for LiFePOβ battery systems, also for NMC/NCM and lead-acid and other DIY-Batterys
New
- New 3D look β chrome-finished battery housing.
- Create a fully customized battery scale directly in the visual editor (voltage points, colors, segment heights, labels).
- 7 custom battery scale presets - create your own favorite!
- Toggleable scale color gradient.
- Disc-style scale with three intensity levels β Subtle, Medium, and Strong.
- Chunk mode completely reworked. (Please provide feedback on whether it displays correctly on iPhone!)
- Selectable battery type completely reworked and further enhanced.
- Visual editor expanded and redesigned.
- Native Home Assistant editor components for a better editing experience.
- Cells and additional sensors can now be added, edited, removed, and sorted directly in the visual editor.
- Custom names and icons for cells and additional sensors.
- Editor available in German and English.
- Auto-Chunk mode β Auto4, Auto8, or Manual.
- Chunk height can be adjusted manually in the editor.
- Chunk cell width can be adjusted manually in the editor.
- Optional smooth color gradients for custom scales.
- Adjustable font size for additional sensors.
- Improved automatic detection of the lowest and highest cell voltage.
- Improved balancing and cell voltage difference display.
- Improved support for voltage sensors using V or mV.
grid_optionsfor controlling the card size.- Significant performance improvements and many other small changes and enhancements.
Full changelog: battery-cell-card/changelog.md at main Β· jinx-22/battery-cell-card Β· GitHub
[!CAUTION]
Note:
The bar heights indicate cell voltage, not state of charge.
The percentage SOC can be read in the legend if an SOC sensor is assigned.
[!TIP]
Editor documentation
Every setting of the visual editor is explained step by step, with the purpose of each option and when it is visible.
Installation
HACS
Click the button to add the repository in HACS, download the card and reload your browser.
Manual Installation
- Download battery-cells-card.js
- Copy it to
/config/www/community/battery-cell-card/ - In Home Assistant:
- Settings
- Dashboards
- Three-dot menu
- Resources
- Add Resource
- URL: /local/community/battery-cell-card/battery-cells-card.js
- Type: JavaScript Module
- Reload browser (CTRL + F5)
The card is now selectable and visible in the GUI.
Github
Support the Project
If you find Battery Cell Card useful, please consider giving this repository a Star! It helps others discover the project and supports further development.
If you would like to support the project even more, a small donation via Donate Bitcoin or Donate Lightning is greatly appreciated.
Every Star and every contribution helps β thank you for your support!
