Hello all, today I updated my instance of Home Assistant, running on a FreeBSD jail (FreeNAS 11.2) and I updated from 0.89. I did the command “pip3 install --upgrade homeassistant” but afther the update, and everything apparently ok, I rebooted HA, and I still see version 0.89 in the info page!
You are correct! I changed the section! Any one can help me understand way I update HA, it gives a success message! If I try to update again it says it’s in most recent versions, but in the UI still shows 0.89!
I wonder if its a web page cache thing. Normally pressing F5 will reload a web page but there have been a few times where I have to use Shift + F5 to actually see changes in HA.
Just curious, Did you stop homeassistant before you tried to upgrade? I’m not 100% sure if it even matters but might be worth a try.
Otherwise it really seems like your running two versions of HA.
Maybe you trying to run and update a version not in a virtualenv but is there anyway possible the HA you’re actually seeing is in a virtualenv. What does the System Health say?
You are correct this is not needed but I still think its a good idea. There’s no additional overhead when using a virtualenv. Curious as to why you would skip this? I found a few times it has made my life easier simply because I was using the virtualenv.
