The previous discussion was helpful but I was all over the place with trouble shooting.
I narrowed it down to when the app is open on my iphone and I touch the physical panel and turn on the heat, the app updates correctly and it shows it’s heating.
If the app has been swiped closed and I turn the heat on at the physical panel and then open the app, it shows heating but also off as in the picture in the previous post.
That seems to be a Home Assistant issue with not communicating when it opens.
That’s because you posted to an unrelated and closed issue. Where he told you to post is the discussions for z-wave js, so that has nothing to do with your iPhone companion app not updating unless you can show it’s happening in z-wave js.
If you saw in the z-wave js logs, for example, that z-wave js is consistently reporting an error when you push the T6 mode button then that might be a good place to ask. That’s why I was trying to get you to follow the logs so you know where to ask for more help.
I don’t know what’s happening in your situation. You showed me logs of the T6 and thus z-wave js updating HA:
If it isn’t consistantly doing that, and z-wave js is showing and error when it doesn’t (or not showing anything at all) then I’d be wondering if it was the T6 itself.
I don’t want to jinx myself but the updates to HA over the last two weeks, zwave js combined with zwave js ui and the firmware update to ZWA-2 seems to have solved my mode update issue.
If we aren’t seeing errors in zwave, is the issue with the core app? Its that the web interface or the app don’t get the initial change from off to heat so it says Heating but Off. Once the initial interaction has happened between the Thermostat and HA, the interface updates normally.
You mentioned before that your T6 was now working ok, but are you saying now that when you press the “Mode” button on the physical T6 that mode is not being reported/updated in Home Assistant?
When you turn on debug in the integration then the Z-Wave JS client enables z-wave js logging and it also logs the the websocket messages for state changes (and more).
When you press the Mode button on the T6 what shows up in those logs?
Everything looks normal. It seems to be that once the T6 communicates to the HA first time I press the physical T6 menu it doesn’t change the mode in the HA (it shows Off and Heating and the furnace turns on), and every physical press after that does change the mode.
BTW, I mentioned before that I never change the mode on mine. I leave mine on auto and have HA set the high/low temps based on the time of day and occupancy, etc.
Yes. The logs are filled with node 010 commands and it actually says Heat. However the mode on HA does change to Heat but still says Off. When I hit the menu to change the mode on the T6 and it moves to Cool, and as expected it updates the mode on the app, etc. Whatever is used to refresh the app for the Mode change, that is where the issue is.
It would nice to figure out if there is someone on Github who might take a look at this but I have tried several times to get their attention but to no avail.
I am not sure what it takes to get someone to look at it, but I added all the logs to a new conversion as Acalzone directed me to do, even sent him money hoping that might help.
You have been very helpful. It’s out of our hands and in the hands of the Github Gods.
What does that mean? The mode on HA changes to Heat but says off? Maybe you are confusing two different things? Or is that a typo?
Or are you saying that you see a z-wave debug message like:
[Thermostat Mode] mode: 0 => 3
which is saying the mode is changing from off to auto BUT your climate entity is not changing state?
(The modes cycles and are 0=off, 1=heat, 2=cool, 3=auto (the HA state is ‘heat_cool’))
Or when it “doesn’t work” do you NOT see that mode change in the debug logs? But is there’s anything else in the logs indicating the T6 sent a message?
Go to physical T6 panel and press mode to turn to heat.
Click on iphone or web interface to see if it’s working correctly. Sometimes it’s does, sometimes it doesn’t.
There’s quite a bit happening between those to points.
Considering it seems to work for most people, you are going to have to do more legwork to narrow it down. I’m repeating I think but…
When it does NOT work at what point does it fail?
Does anything show up in the logs? i.e. is the T6 sending the the state change to z-wave js? i.e. is the T6 faulty?
Are you seeing the logs in z-wave js but not in HA’s logs when z-wave integration is in debug mode?
If you are seeing the state change in the HA logs, are you seeing the WSMessage or [Thermostat Mode] mode: 0 => 3 message?
If you are seeing the mode change message then are you seeing the state change in Developer Tools?
If so, does the UI reflect what the state is in Developer Tools?
Right now there’s been 92 views on this thread alone.
Do the above and provide concise logs (just the important parts) that show what step is failing and/or include screenshot of Dev Tools showing where the state is not being updated. Where along that path it fails will help determine who looks at it.
