Update Integration component from github
Hi all,
I have a problem with the modbus protocol, and there is already a new modbus update on github,
how to do the update on the HAOS Raspberry Pi 3 B?
I assume you are talking about the core modbus integration?
Wait for the next version of Home Assistant to be released, or…
Install the updated version as a custom component and it will be used in preference to the core version. You can then remove this when Home Assistant is updated but you will have to set up the integration again.
Thanks for the advice, I’ll try to do that later and see if it works
