Hi I had updated HA last month which killed my setup. I spent 2 days figuring out why it crashed, so I had to install a fresh HA installation and import all the components later on. I ran flawlessly until today , when I wanted to update to the July version. Update done: HA killed. Can’t login anymore, Logs show that it crashes. Only thing that generates a warning is about some Mosquitto Bridge setup error, but with these lines in I was able to restart HA many times ( I always test the config). This is so frustrating.
Without the actual error logs we can’t help.
Thank, Since I can’t login, I can only see the logs flash by in the virtual box. How can I access the actual log files?i have smb set up but there are no logs in the share
