Update lock for esphome modbus to prevent accidental write
Can anyone suggest a way to prevent modbus entities writing back a changed value?
Ideally I would like a toggle switch that if set to off prevents any modbus values being written and they only switch into write mode if I switch the switch.
My use case is my inverter which through scrolling on my phone I have accidentally slid a number slider and set the max charge current to a new value. I do not know what the old value was.
Remove the modbus.write_register from the slider’s tap action and place a button next to it which does write when being tapped.
Had a similar problem and now it looks like this
slider+button
If the slider being moved the value does change and the button next to slider does change it’s icon color, being an indicator that if I want to set the new value I must press the button.
And don’t argue about the ‘old’ value in the button is sort of mixed up, that’s a bug, better said I was in need of the wattage once and missed to revert it back so it still displays the chargerate. In the end these 2 values shown in the button aren’t required since if you revert the slider position back to it’s old position the button will turn green without being pressed.
