Update MQTT entity id's
Hi there!
Have searched and searched, but cant find a resource for this question. Maybe one of you can help.
Ive set up Mosquitto broker and everything is working fine. Only problem is, that my entity ID’s are all wrong. After Hassio discovered them, they where given an entity ID, that are completely wrong (since i copied the configuration of another Sonoff device). Problem now is that Hassio wount update the entity ID. Is there any other way to update them than to do it manually via the UI? The config on the sonoff device is updated, but not picking this up in Hassio.
Friendly name updates ok, but not entity ID.
Any help would be greatly appreciated!
Do you have any news regarding this issue? I have the same problem…
Moved my installation from a RaspberryPI to an old laptop, that sorted it. Started all over again. For completely different reasons though… Sorry.
