Update OpenUV component
I noticed, that this component is sending http request while setting up sensors and if it fails to get the right response (e.g.because the daily limit of requests has been reached) it does not set up the sensors at all.
It happens when I’m e.g restarting HA in the evening. And obviously it causes errors like this:
[homeassistant.components.openuv] Config entry failed: Invalid API key
[homeassistant.config_entries] Config entry for openuv not ready yet. Retrying in 80 seconds.
And then also in the UI.
Would it be possible to set up the sensors independently with the default state ‘unknown’ and then the state can be updated later on (anytime) by calling openuv.update_data service?
