Update text sensor with http api
Hello …
Is there a way to use the http rest api to update a “text sensor” (i guess i will use a helper there).
I am already updating sensor (float) and binary_sensor (bool), and it works great.
I am looking for a similar capability for text (str).
Thanks for a recommendation.
Cheers
Probably /api/services/<domain>/<service> where the domain is input_text and the service is input_text.set_value.
Depending on what kind of text, you can have a sensor entity with a text state, no different than the float. In fact, sensor states are always strings in HA. The key issue to watch out for is the 255-character (I believe) limit on the length of a state string.
Thank you to all. I had miss understood the documentation which only gives example for sensor and binary_sensor. I guess this is because those two (unlike others) are DYNAMICALLY created (i.e. no need to manually create a helper for those using HA GUI)
