Update to 0.17.4 from 0.16.7 not working
I have tried to update to 0.17.4 from 0.16.7 several times and when I do Appdaemon fails to start and keeps looping with this in the logs
[00:00:42] INFO: Starting AppDaemon…
2025-06-14 00:00:45.575673 INFO AppDaemon: ------------------------------------------------------------
2025-06-14 00:00:45.576071 INFO AppDaemon: AppDaemon Version 4.5.8 starting
2025-06-14 00:00:45.576177 INFO AppDaemon: ------------------------------------------------------------
2025-06-14 00:00:45.576254 INFO AppDaemon: Python version is 3.12.10
2025-06-14 00:00:45.576492 INFO AppDaemon: Configuration read from: /config/appdaemon.yaml
2025-06-14 00:00:45.576672 INFO AppDaemon: Added log: AppDaemon
2025-06-14 00:00:45.576769 INFO AppDaemon: Added log: Error
2025-06-14 00:00:45.576837 INFO AppDaemon: Added log: Access
2025-06-14 00:00:45.576899 INFO AppDaemon: Added log: Diag
[00:00:45] INFO: Service AppDaemon exited with code 0 (by signal 0
anyone else seeing this?
I have exactly the same issue and no solution yet
AppDaemon 4.5.11 was just released with some bugs fixed. Let’s hope the updated Addon (0.17.6) will soon be available. There was something wrong with github CI for 0.17.5, so at least my HA never updated to that version. (@frenck)
0.17.6 seems to have fixed the issue for me!
I’m still broken if I try to use .17.6
I’m stuck in a loop:
025-06-26 22:08:17.438928 INFO HASS: Authenticated to Home Assistant 2025.6.3
2025-06-26 22:08:17.440344 INFO HASS: Waiting for Home Assistant to start
2025-06-26 22:08:17.474846 WARNING HASS: Disconnected from Home Assistant, retrying in 5 seconds
2025-06-26 22:08:17.501143 INFO AppDaemon: Stopping apps from namespace 'default' because the plugin failed
2025-06-26 22:08:17.501442 INFO AppDaemon: Stopping apps: {'qolsys_panel', 'hello_world'}
2025-06-26 22:08:17.501585 INFO AppDaemon: Calling terminate() for 'qolsys_panel'
2025-06-26 22:08:17.502880 INFO qolsys_panel: Terminating
2025-06-26 22:08:17.504245 INFO qolsys_panel: Terminated
2025-06-26 22:08:17.506501 INFO qolsys_panel: listening cancelled
Did anyone ever figure this out?
AFAICS, the only solution is to not upgrade AppDaemon. My system is happy with 0.17.4 and I therefore see no reason to upgrade it.
Yet again, I’ve updated to 17.13 by mistake and had to roll-back to 17.4 again so that Schedy would work.
Has anybody got to the bottom on why Schedy started to misbehave after 17.4 or thereabouts?
