## Failed to start add-on
409 Client Error for http+docker://localhost/v1.40/containers/create?name=addon_15ef4d2f_esphome: Conflict ("Conflict. The container name "/addon_15ef4d2f_esphome" is already in use by container "2e9a94e526a61da32051ab440f20ed2d932a568313b0a1aa27ea03e24c7bf7c4". You have to remove (or rename) that container to be able to reuse that name.")
I do also have the dev one installed from the same add-on repo but that is disabled since you can’t run both at the same time.
Umm, no mate. I hit the ‘update’ button on the add-on. Pretty much impossible to mix that up with installing a completely different add-on…
You can see in the screenshot that the ‘community’ version is not installed (no orange bar).
Strangely this seems to be the same kind of error I had when trying to upgrade HA from 2021.5.4 to 2021.6. I was getting ‘same container name’ issues and had to stop HA and run the update via CLI.
