Hi, is there anyway to upgrade the zigbee2mqtt addon not to latest but to a specific version? Reason is, my HA core is pretty old and the latest zigbee2mqtt requires latest HA core.
It will take me while to bring the HA core to the latest version.
If you have a backup, you could downgrade using that one by selecting ‘partial backup’:
Unfortunately, this is not what I want. I just want to update to specific version which is newer than the current version but not the latest one.
Something like the HA core where you can install specific version through cmdline. This way we can fix things that broken in steps.
Hello, I have the same need!. Did you manage to figure out how to do this? Thanks!
bumping this since I’m looking to upgrade from 1.41.0 to 1.42.0 to implement #24588 Fix SNZB-03 detected as SQ510A
I know 2.0.0 has breaking changes and I will update to 2.0.0 eventually once I read through the documentation`
It’s not a huge project to update. I added the lines as stated in the documentation, restarted the add-on and then updated. After a restart of HA everything was back up, took around 2 minutes. Just do a backup first.
Similar issue here but for node-red addon.
I need to upgrade my addon
but I can’t upgrade to the lastest version because this version has a braking change.
How can hoose the version of the addon when upgrading ?
I’m looking for instructions to update to specific version instead of to 2.1.3-1 . I’m on 1.33.1-1 and don’t want to risk my setup to stop working because of these major changes in 2.0, but I need to update because Ikea motion sensor shows as unsupported…
