Updated Release β€” HDAnywhere MHUB Local Control Integration
Hey everyone :wave:
Here is the updated version of my custom integration for HDAnywhere MHUB systems, bringing full local IP control directly into Home Assistant.
:desktop_computer: HDAnywhere MHUB (Local Control)
Control your MHUB matrix directly from Home Assistant with fast, local communication β€” no cloud required.
:sparkles: Features
:white_check_mark: Power Control
Turn the MHUB ON/OFF using a dedicated switch.
:control_knobs: Video Routing Control
Quickly route inputs to outputs directly from Home Assistant.
:mag: Automatic Device Detection
  • Detects MHUB model
  • Detects firmware version
  • Detects API version
  • Automatically detects input/output configuration
:wrench: Improved Compatibility
Supports both new and legacy MHUB firmware platforms, including:
  • MHUB 4Γ—4
  • MHUB 6Γ—6
  • MHUB 8Γ—8
  • MHUB S series
  • MHUB 100A series
:lock: 100% Local Control
All communication happens locally via the MHUB API β€” no internet required.
:jigsaw: Installation
Option 1 β€” Install via HACS (Recommended)
Add the repository to HACS:
Category: Integration
Then:
  1. Install the integration through HACS
  2. Restart Home Assistant
  3. Go to Settings β†’ Devices & Services β†’ Add Integration
  4. Select HDAnywhere MHUB
:gear: Setup
Enter your MHUB connection details.
IP Address
Example:
192.168.88.150
API Port
Default:
80
(Only change if modified in MHUB settings)
Click Submit to complete setup.
:bulb: Tip:
You can find the MHUB IP address in:
  • Your router’s DHCP client list
  • The MHUB app β†’ System Info β†’ Network
:package: Repository
:man_technologist: Credits
Author: Michael Marsh (@marsh4200)
In collaboration with: SMARTHOME21
:page_facing_up: Version
v0.0.3
Improvements include:
  • Improved MHUB model detection
  • Added API version support
  • Improved firmware detection
  • Improved input/output detection
  • Improved compatibility with older MHUB systems
