Updated to 0.76.2 from 0.75.3, cannot load front end
So home assistant appears to be up, sorta. I can SSH in and check the logs, reboot etc. But i can’t load the front end, not on mobile or on a computer.
upgrade took about 35 minutes to do the db migration and seemed to work fine.
no obvious errors in the logs so not sure how to troubleshoot this so appreciate any input. thanks.
Also, I am using the MariaDB add-on, how can I blow away the database and start over?
