Updated to Core 2022.3.2 : can't update HACS, supervisor disappeared from menu
Hi all,
after updating from an older version to Core 2022.3.2, there are two things I noticed:
1: Supervisor disappeared from the left menubar, even if I can still kind of access it from /hassio/dashboard. … What happened? it’s not called supervisor anymore? Where can I read more about it?
2: I used HACS for some integration. It doesn’t seem to behave correctly now, when I add a new repository, I can’t find the new intergration afterwards.
So I think I should update HACS… but when I do from the UI, it doesn’t seem to be working :
then
Then I restart everything (also tried rebooting the machine altogether) and … I still have 1.16
Any Hints?
Supervisor is now under configuration. It changed a few releases ago, go thru the blog entries.
Hacs, not sure.
Current Version of HACS, is 1.23.0 … in my “homeassistant OS” , so it seems strange that you get 1.20.0, unless that’s required, before getting 1.23.0 … try to update HACS manually
I’m facing the same problem, after updateting Home Assistant to 2022.3.3. I’m not able to update HACS or any custom component within the UI. It although suggests HACS v. 1.20.0.
How can I update it manually? I already copied an updated version to /custom-components/hacs which doen’t work (HACS dissapeared).
edit: have to correct myself, manual update did work. But still 1.20.0.
Come on guys, HACS issues go here on github Issues · hacs/integration · GitHub. It is plainly stated so on the HACS help page. https://hacs.xyz/docs/issues
Hey all for anyone uncertain, it’s pretty easy if you have an SSH addon enabled.
1: SSH in,
2: As per the HACS download page, run:
wget -O - https://get.hacs.xyz | bash -
3: Restart
4: best of luck!
I am facing same problem
this helped me alot, thanks!
