HAOSKiosk allows users to view their dashboards and control Home Assistant using a display attached directly to their HAOS server (e.g., RPi or miniPC).
This efficient, standalone setup avoids the need to use/setup/power a separate device, screen and associated browser just to manage and monitor your HA instance, saving cost, energy, and space.
This update adds 2 important new user functionalities:
OnScreen keyboard for use with touchscreens that allow you to fully control HA and its dashboards with just a touchscreen attached to your HAOS server – no other devices, peripherals, browsers, or displays required. (Of course, you can still use an external keyboard and mouse to interact with HAOSKiosk if you don’t have a touchscreen)
REST API to allow: (a) remote launching of new URL’s/dashboards, (b) control to automatically turn on/off display or refresh the browser (c) ability to launch one or more commands in the HAOSKiosk container for even more custom control of the add-on.
In particular, the REST API can be used to create automations and services to:
Turn on/off display based on time-of-day, proximity, event triggers,
voice commands, etc. -
Send dashboard (or another 3rd party URL) to HAOSKiosk display based o event triggers or pre-programmed rotation (e.g., to sequentially view different cameras).
Here is the udpated README:
HAOS-kiosk
Display HA dashboards in kiosk mode directly on your HAOS server.
Author: Jeff Kosowsky
Description
Launches X-Windows on local HAOS server followed by OpenBox window manager
and Luakit browser.
Standard mouse and keyboard interactions should work automatically.
Supports touchscreens (including onscreen keyboard) and screen rotation.
Includes REST API that can be used to control the display state and to send
new URLs (e.g., dashboards) to the kiosk browser.
You can press ctl-R at any time to refresh the browser.
NOTE: You must enter your HA username and password in the
Configuration tab for add-on to start.
NOTE: If display does not show up, reboot with display attached (e.g.,
via HDMI cable)
Note: Luakit browser is launched in kiosk-like (passthrough) mode.
To enter normal mode (similar to command mode in vi), press
ctl-alt-esc.
You can then return to passthrough mode by pressing ctl-Z or enter
insert mode by pressing i.
See luakit documentation for available commands.
In general, you want to stay in passthrough mode.
NOTE: Should support any standard mouse, touchscreen, keypad and
touchpad so long as their /dev/input/eventN number is less than 25.
NOTE: If not working, please first check the bug reports (open and
closed), then try the testing branch (add the following url to the
repository: GitHub - puterboy/HAOS-kiosk: Display HA dashboards in kiosk mode directly on your HAOS server). If still no
solution, file an issue on github
bug report and include
full details of your setup and what you did along with a complete log.
Configuration Options
HA Username [required]
Enter your Home Assistant login name.
HA Password [required]
Enter your Home Assistant password.
HA URL
Default: http://localhost:8123
In general, you shouldn’t need to change this since this is running on the
local server.
HA Dashboard
Name of starting dashboard.
(Default: “” - loads the default Lovelace dashboard)
Login Delay
Delay in seconds to allow login page to load.
(Default: 1 second)
Zoom Level
Level of zoom with 100 being 100%.
(Default: 100%)
Browser Refresh
Time between browser refreshes. Set to 0 to disable.
Recommended because with the default RPi config, console errors may
overwrite the dashboard.
(Default: 600 seconds)
Screen Timeout
Time before screen blanks in seconds. Set to 0 to never timeout.
(Default: 0 seconds - never timeout)
Output Number
Choose which of the connected video output ports to use. Set to 1 to
use the first connected port. If selected number exceeds number of
connected ports, then use last valid connected port. (Default: 1)
NOTE: This should always be set to 1 unless you have more than one video
output device connected. If so, use the logs to see how they are numbered.
Dark Mode
Prefer dark mode where supported if true (Default: true)
HA Sidebar
Presentation of left sidebar menu (device-specific).
Options include: (Default: None)
- Full (icons + names)
- Narrow (icons only)
- None (hidden)
Rotate Display
Rotate the display relative to standard view.
Options include: (Default: Normal)
- Normal (No rotation)
- Left (Rotate 90 degrees clockwise)
- Right (Rotate 90 degrees counter-clockwise)
- Inverted (Rotate 180 degrees)
Map Touch Inputs
Map touch inputs to the selected video output, so that the touch devices
get rotated consistently with the video output. (Default: True)
Cursor Timeout
Time in seconds for cursor to be hidden after last mouse movement or touch.
Cursor will reappear when mouse moved or screen touched again. Set to 0
to always show cursor. Set to -1 to never show cursor. (Default: 5
seconds)
Keyboard Layout
Set the keyboard layout and language. (Default: us)
Onscreen Keyboard
Display an on-screen keyboard when keyboard input expected if set to
true. (Default: false)
To move, resize, or configure keyboard options, long press on the ...
within the Return key. You can also resize the keyboard by pressing and
dragging along the keyboard edges.
You can manually toggle keyboard visibility on/off by tapping extreme top
right of screen.
See GitHub - dr-ni/onboard: Onboard is an onscreen keyboard useful for everybody that cannot use a hardware keyboard; for example TabletPC users, mobility impaired users,... for more details
Save Onscreen Config
Save and restore changes to onscreen keyboard settings made during each
session if set to true. Overwrites default settings. (Default: true)
Xorg.conf
Append to or replace existing, default xorg.conf file.
Select ‘Append’ or 'Replace options.
To restore default, set to empty and select ‘Append’ option.
REST Port
Port used for the REST API. Must be between 1024 and 49151. (Default: 8080)
Note for security REST server only listens on localhost (127.0.0.1)
REST Bearer Token
Optional authorization token for REST API. (Default: “”) If set, then add
line Authorization: Bearer <REST_BEARER_TOKEN> to REST API calls.
Allow User Commands
Allow user to run arbitrary one or more commands in the HAOSkiosk container
via the respective REST APIs: run_command and run_commands (Default:
false)
Warning: Allowing this could allow the user to inject potentially dangerous
root-level commands
Debug
For debugging purposes, launches Xorg and openbox and then sleeps
without launching luakit.
Manually, launch luakit (e.g.,
luakit -U localhost:8123/<your-dashboard>) from Docker container.
E.g., sudo docker exec -it addon_haoskiosk bash
REST APIs
launch_url {“url”: “<url>”}
Launch the specified ‘url’ in the kiosk display. Overwrites current active
tab.
Usage:
curl -X POST http://localhost:<REST_PORT>/launch_url -H "Content-Type: application/json" -d '{"url": "<URL>"}'
refresh_browser
Refresh browser
Usage:
curl -X POST http://localhost:<REST_PORT>/refresh_browser
is_display_on
Returns boolean depending on whether display is on or off.
Usage:
curl -X GET http://localhost:8080/is_display_on
display_on {“timeout”: “<timeout>”}
Turn on display. If optional payload given, then set screen timeout to
<timeout> which if 0 means never turn off screen and if positive
integer then turn off screen after <timeout> seconds
Usage:
curl -X POST http://localhost:<REST_PORT>/display_on
curl -X POST http://localhost:8080/display_on -H "Content-Type: application/json" -d '{"timeout": <timeout>}
display_off
Turn off display
Usage:
curl -X POST http://localhost:<REST_PORT>/display_off
xset
Run xset <args> to get/set display information. In particular, use -q
to get display information.
Usage:
curl -X POST http://localhost:<REST_PORT>/xset -H "Content-Type: application/json" -d '{"args": "<arg-string>"}'
current_processes
Return number of currently running concurrent processes out of max allowed
Usage: curl -X GET http://localhost:8080/current_processes
run_command {“cmd”: “<command>”}
Run command in the HAOSKiosk Docker container where cmd_timeout is an
optional timeout in seconds.
Only allowed if Allow User Commands option is set to true.
Usage:
curl -X POST http://localhost:<REST_PORT>/run_command -H "Content-Type: application/json" -d '{"cmd": "<command>", "cmd_timeout": <seconds>}'
run_commands {“cmds”: [“<command1>”, “<command2>”,…], “cmd_timeout”: <seconds>}}
Run multiple commands in the HAOSKiosk Docker container where cmd_timeout
is an optional timeout in seconds.
Usage:
curl -X POST http://localhost:<REST_PORT>/run_commands -H "Content-Type: application/json" -d '{"cmds": ["<command1>", "<command2>",...], "cmd_timeout": <seconds>}'
NOTE: The API commands logs results to the HAOSkiosk log and return:
"success": bool,
"result": {
"success": bool,
"stdout": str,
"stderr": str,
"error": str (optional)
Note that run_commands returns an array of "results" of form:
"results": [{"success": bool, "stdout": str, "stderr": str, "error": str (optional)},...]
You can format the stdout (and similarly stderr) by piping the output to:
jq -r .result.stdout
In the case of run_commands, pipe the output to:
jq -r '.results[]?.stdout'
You can also configure all the above REST commands in your
configuration.yaml as follows (assuming REST_PORT=8080)
rest_command:
haoskiosk_launch_url:
url: "http://localhost:8080/launch_url"
method: POST
content_type: "application/json"
payload: '{"url": "{{ url }}"}'
haoskiosk_refresh_browser:
url: "http://localhost:8080/refresh_browser"
method: POST
payload: "{}"
haoskiosk_is_display_on:
url: "http://localhost:8080/is_display_on"
method: GET
haoskiosk_display_on:
url: "http://localhost:8080/display_on"
method: POST
payload: '{% if timeout is defined and timeout is number and timeout >= 0 %}{"timeout": {{ timeout | int }}}{% else %}{}{% endif %}'
haoskiosk_display_off:
url: "http://localhost:8080/display_off"
method: POST
payload: "{}"
haoskiosk_current_processes:
url: "http://localhost:8080/current_processes"
method: GET
haoskiosk_xset:
url: "http://localhost:8080/xset"
method: POST
payload: '{"args": "{{ args }}"}'
haoskiosk_run_command:
url: "http://localhost:8080/run_command"
method: POST
payload: '{% if cmd_timeout is defined and cmd_timeout is number and cmd_timeout > 0 %}{"cmd": "{{ cmd }}", "cmd_timeout": {{ cmd_timeout | int }}}{% else %}{"cmd": "{{ cmd }}"}{% endif %}'
haoskiosk_run_commands:
url: "http://localhost:8080/run_commands"
method: POST
payload: '{% if cmd_timeout is defined and cmd_timeout is number and cmd_timeout > 0 %}{"cmds": {{ cmds | tojson }}, "cmd_timeout": {{ cmd_timeout | int }}}{% else %}{"cmds": {{ cmds | tojson }}}{% endif %}'
Note if optional `REST_BEARER_TOKEN~ is set, then add the following two
authentication lines to each of the above stanzas:
headers:
The rest commands can then be referenced from automation actions as:
rest_command.haoskiosk_<command-name>
For example:
actions:
- action: rest_command.haoskiosk_launch_url
url: "https://homeassistant.local/my_dashboard"
- action: rest_command.haoskiosk_is_display_on
- action: rest_command.haoskiosk_display_on
timeout: 300
- action: rest_command.haoskiosk_display_off
- action: rest_command.haoskiosk_run_command
cmd: "command"
cmd_timeout: <seconds>
args: "<arg-string>"
- action: rest_command.haoskiosk_current_processes
- action: rest_command.haoskiosk_refresh_browser
- action: rest_command.haoskiosk_run_commands
cmds:
- "<command1>"
- "<command2>"
REST API Use Cases
Create automations and services to:
voice commands, etc.See ‘examples’ folder for trigger based on ultrasonic distance and HA
boolean sensor. -
Send dashboard or other url to HAOSKiosk display based on event
different cameras).
Use custom command(s) to change internal parameters of HAOSKiosk and the
luakit browser configuration.
