Updater.updater not showing between sensors
I have updater: inside configuration.yaml so i must have updater.updater inside the sensors or not? If yes, why i don’t have it?
It only appears when there is an update.
Thanks, so it useless to create an automation with that sensor to have a persistent notification when an update is released?
No, create the automation, as soon as the update is available, updater.updater will change state and the persistent notification will be created.
