Updating Bluetooth Proxy Message to 2025.5.0 not going away
I have a repair message saying:
To improve Bluetooth reliability and performance, we highly recommend updating esp32-bluetooth-proxy-913c3c with ESPHome 2025.5.0 or later. When updating the device from ESPHome earlier than 2022.12.0, it is recommended to use a serial cable instead of an over-the-air update to take advantage of the new partition scheme.
I’ve updated to INFO ESPHome 2025.5.2 but the repaired message won’t go away.
Did you update the device or just the add-on?
I updated the devices. I looked at the logs to be sure and the devices seem to be reporting 2025.5.2
You can open a new issue here: GitHub · Where software is built
