Updating does not work
18
I dit the same as Bruh sudo su -s /bin/bash hass
no password entry
tried without sudo the same
You will need to modify the direction based on how you installed homeassistant. You will likely need to use homeassistant rather than hass
If you installed with the AIO installer then see here, or here if you used the virtual environment option.
