Hi guys, I am in trouble trying to update my Pi3 from 0.91.1 to 0.92.2 using a Pi3 and Raspbian Stretch.
I have have been updating the system with no problem at all, but this time something is wrong. I hope someone could help me to identify what should have to be done in order to update my system. Thanks for your help on this.
Below is the log after trying to update:
pi@hassbian:~ $ sudo -u homeassistant -H -s
homeassistant@hassbian:/home/pi $ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@hassbian:/home/pi $ pip3 install --upgrade homeassistant
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting homeassistant
Using cached https://files.pythonhosted.org/packages/92/c8/cf2e3063087970f82fd5cfcdc05445d15ebe01de768e9becc4b77bcb4eeb/homeassistant-0.92.2-py3-none-any.whl
Requirement already satisfied, skipping upgrade: certifi>=2018.04.16 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2019.3.9)
Collecting ruamel.yaml==0.15.91 (from homeassistant)
Downloading https://files.pythonhosted.org/packages/ad/0d/c9f94a393b9b8825accca0bc17afb6cbb7719e8601d26d06cbf7b21abfa3/ruamel.yaml-0.15.91.tar.gz (309kB)
|ββββββββββββββββββββββββββββββββ| 317kB 1.1MB/s
Requirement already satisfied, skipping upgrade: jinja2>=2.10 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant) (2.10)
Collecting cryptography==2.6.1 (from homeassistant)
Using cached https://files.pythonhosted.org/packages/07/ca/bc827c5e55918ad223d59d299fff92f3563476c3b00d0a9157d9c0217449/cryptography-2.6.1.tar.gz
Installing build dependencies ... error
ERROR: Complete output from command /srv/homeassistant/bin/python3 /srv/homeassistant/lib/python3.5/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-o8pf34ih/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- 'setuptools>=18.5' wheel 'cffi>=1.8,!=1.11.3; python_implementation != '"'"'PyPy'"'"'':
ERROR: Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple, https://www.piwheels.org/simple
Collecting setuptools>=18.5
Using cached https://files.pythonhosted.org/packages/ec/51/f45cea425fd5cb0b0380f5b0f048ebc1da5b417e48d304838c02d6288a1e/setuptools-41.0.1-py2.py3-none-any.whl
Collecting wheel
Using cached https://files.pythonhosted.org/packages/bb/10/44230dd6bf3563b8f227dbf344c908d412ad2ff48066476672f3a72e174e/wheel-0.33.4-py2.py3-none-any.whl
Collecting cffi!=1.11.3,>=1.8
Using cached https://files.pythonhosted.org/packages/93/1a/ab8c62b5838722f29f3daffcc8d4bd61844aa9b5f437341cc890ceee483b/cffi-1.12.3.tar.gz
Collecting pycparser (from cffi!=1.11.3,>=1.8)
Using cached https://www.piwheels.org/simple/pycparser/pycparser-2.19-py2.py3-none-any.whl
Building wheels for collected packages: cffi
Building wheel for cffi (setup.py): started
Building wheel for cffi (setup.py): finished with status 'error'
ERROR: Complete output from command /srv/homeassistant/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-3s5i_jpj/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-r2k400xc --python-tag cp35:
ERROR: Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing `libffi.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libffi' found
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.5
creating build/lib.linux-armv7l-3.5/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/recompiler.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/error.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/cparser.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/model.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/api.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/__init__.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/commontypes.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/lock.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/verifier.py -> build/lib.linux-armv7l-3.5/cffi
copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.5/cffi
copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.5/cffi
copying cffi/_embedding.h -> build/lib.linux-armv7l-3.5/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.5/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-armv7l-3.5
creating build/temp.linux-armv7l-3.5/c
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -g -fdebug-prefix-map=/build/python3.5-6waWnr/python3.5-3.5.3=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/srv/homeassistant/include -I/usr/include/python3.5m -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.5/c/_cffi_backend.o
c/_cffi_backend.c:15:17: fatal error: ffi.h: No such file or directory
#include <ffi.h>
compilation terminated.
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
ERROR: Failed building wheel for cffi
Running setup.py clean for cffi
Failed to build cffi
Installing collected packages: setuptools, wheel, pycparser, cffi
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
ERROR: Complete output from command /srv/homeassistant/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-3s5i_jpj/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-t52bzsf0/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-o8pf34ih/overlay --compile --install-headers /srv/homeassistant/include/site/python3.5/cffi:
running install
running build
running build_py
creating build
running build_ext
#include <ffi.h>
ERROR: Command "/srv/homeassistant/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-3s5i_jpj/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-t52bzsf0/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-o8pf34ih/overlay --compile --install-headers /srv/homeassistant/include/site/python3.5/cffi" failed with error code 1 in /tmp/pip-install-3s5i_jpj/cffi/
ERROR: Command "/srv/homeassistant/bin/python3 /srv/homeassistant/lib/python3.5/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-o8pf34ih/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- 'setuptools>=18.5' wheel 'cffi>=1.8,!=1.11.3; python_implementation != '"'"'PyPy'"'"''" failed with error code 1 in None
