Updating from 2021.8.1 kills my slae.sh cc2652rb stick_
I’ve tried to update my home assistant following 2021.8.1 and every time my zigbee stick becomes undetected.
I did manage to update the OS without issue to the latest version, but every time I run the core updates. poof, gone.
Here’s what comes up after the system restarts following the update.
slae.sh cc2652rb stick - s - /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_22_98_A3_ED-if00-port0, s/n: 00_12_4B_00_22_98_A3_ED - Silicon Labs - 10C4:EA60
Zigbee Home Automation
Do you want to setup slae.sh cc2652rb stick - s - /dev/serial/by-id/usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_22_98_A3_ED-if00-port0, s/n: 00_12_4B_00_22_98_A3_ED - Silicon Labs - 10C4:EA60?
Aborted
Failed to probe the usb device
Following this, my Tuya integrations, Zigbee2mqtt both fail.
Restoring from backup returns everything to normal.
Could your issue be similar to this one?
It could, but the issue is that the stick isn’t being detected after the upgrade - see my initial post with the error message.
