e6on
(e6on)
1
Updating to 0.105.4 is not working to me. How I fix this?
20-02-15 19:24:34 ERROR (SyncWorker_0) [hassio.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.105.4 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.105.4: No such image: homeassistant/raspberrypi3-homeassistant:0.105.4").
20-02-15 19:24:34 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
doubleUS
(Wilfred)
2
You’re out of disk space.
e6on
(e6on)
3
The root is out of space. Is that the problem?
~ $ df -h
Filesystem Size Used Available Use% Mounted on
overlay 28.6G 2.0G 25.2G 7% /
tmpfs 64.0M 0 64.0M 0% /dev
tmpfs 462.0M 0 462.0M 0% /sys/fs/cgroup
shm 64.0M 0 64.0M 0% /dev/shm
/dev/root 93.8M 93.8M 0 100% /sbin/docker-init
/dev/mmcblk0p8 28.6G 2.0G 25.2G 7% /ssl
/dev/mmcblk0p8 28.6G 2.0G 25.2G 7% /addons
/dev/mmcblk0p8 28.6G 2.0G 25.2G 7% /backup
/dev/mmcblk0p8 28.6G 2.0G 25.2G 7% /share
/dev/mmcblk0p8 28.6G 2.0G 25.2G 7% /data
/dev/mmcblk0p8 28.6G 2.0G 25.2G 7% /config
/dev/mmcblk0p8 28.6G 2.0G 25.2G 7% /etc/resolv.conf
/dev/mmcblk0p8 28.6G 2.0G 25.2G 7% /etc/hostname
/dev/mmcblk0p8 28.6G 2.0G 25.2G 7% /etc/hosts
tmpfs 462.0M 0 462.0M 0% /proc/asound
tmpfs 64.0M 0 64.0M 0% /proc/keys
tmpfs 64.0M 0 64.0M 0% /proc/latency_stats
tmpfs 64.0M 0 64.0M 0% /proc/timer_list
tmpfs 64.0M 0 64.0M 0% /proc/sched_debug
tmpfs 462.0M 0 462.0M 0% /sys/firmware
I try to update right now too, and have the same issue. And the same situation at sd-card… I think it’s outside of our problems.
e6on
(e6on)
5
This is fixed on the HassOS 3.11 release.
I am having the same issue with HassOS 3.13 and updating to both HA 0.110.1 and .2. in both cases it’s blown up my install and I have had to rebuild.
