Running latest OS with Core 2025.1.2, I upgraded to 2025.1.3 and everything fails. All devices except a wifi bulb is unavailable. Can’t turn off any light, can’t turn any on.
In the integration, it says Failed to set up: Check the logs
What I tried so far:
Reboot system
Downgraded to 2025.1.2
Changed port
Changed extension cable
Power off, remove the stick, start without (and also the BT-stick). Connected ZBT-1 (but not BT), rebooted by prompt. No difference.
It shows up with lsusb: Bus 001 Device 002: ID 10c4:ea60 Nabu Casa Home Assistant Connect ZBT-1
For some reason I can’t copy paste the log so it attach with a screenshot instead.
It doesn’t look like hardware failure but to keep peace at home, I ordered a spare stick arriving tomorrow just in case. But I can’t interpret the log to find out what the solution is.
Can anyone assist so I can solve this before bedtime? Local time is 16:00 GMT+1.
Additional information:
Running on a HP Pro Desk stand alone.
Restored backup from this morning, some 15 hours ago. No difference.
But after disabling all quirks and rebooted system, some function is restored via UI. Several Aqara-sensors not working. Both Philips Hue works. Just after posting, the temp sensors works again.
A lot of errors related to the Aqara WRS-R01. Never got it working cause I got error trying to change click mode from single (to double, triple). Check beneath.
#2025-01-21 20:22: All quirks temporary disabled as trouble shooting.
##2025-01-18 12:06: Attemp to fix Aqara WRS-R02. https://github.com/zigpy/zha-device-handlers
#zha:
# database_path: /config/zigbee.db
# enable_quirks: True
# custom_quirks_path: /config/custom_zha_quirks
##2025-01-18 12:39: Attemp to make it possible to flash firmware on Philips-devices: https://github.com/Koenkk/zigbee-OTA
#zha:
# zigpy_config:
# ota:
# otau_directory: /config/zigpy_ota
# z2m_remote_index: https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/index.json
##2025-01-18 17:33: Log level defined to debug temporary.
#logger:
# default: debug
Seems to be correct with z2m even if it's ZHA.
