Hi, I got this Error at the end of upgrading. Thx for helping.
Cleaning up...
Command python setup.py egg_info failed with error code 1 in /tmp/pip-build-148d257t/aiohttp
Storing debug log for failure in /home/hass/.pip/pip.log
Log:
pi@raspberrypi:~ $ sudo su -s /bin/bash hass
hass@raspberrypi:/home/pi$ pip3 install --upgrade homeassistant
Downloading/unpacking homeassistant
Downloading homeassistant-0.43.2-py2.py3-none-any.whl (7.0MB): 7.0MB downloaded
Downloading/unpacking voluptuous==0.9.3 (from homeassistant)
Downloading voluptuous-0.9.3.tar.gz
Running setup.py (path:/tmp/pip-build-148d257t/voluptuous/setup.py) egg_info for package voluptuous
WARNING: Could not locate pandoc, using Markdown long_description.
Downloading/unpacking requests>=2,<3 from https://pypi.python.org/packages/7e/ac/a80ed043485a3764053f59ca92f809cc8a18344692817152b0e8bd3ca891/requests-2.13.0-py2.py3-none-any.whl#md5=5e432dcf5bd1e3402ea1656700d99365 (from homeassistant)
Downloading requests-2.13.0-py2.py3-none-any.whl (584kB): 584kB downloaded
Downloading/unpacking chardet==3.0.2 (from homeassistant)
Downloading chardet-3.0.2-py2.py3-none-any.whl (133kB): 133kB downloaded
Downloading/unpacking pip>=7.1.0 (from homeassistant)
Downloading pip-9.0.1-py2.py3-none-any.whl (1.3MB): 1.3MB downloaded
Downloading/unpacking async-timeout==1.2.0 (from homeassistant)
Downloading async_timeout-1.2.0-py3-none-any.whl
Downloading/unpacking aiohttp==2.0.7 (from homeassistant)
Downloading aiohttp-2.0.7.tar.gz (739kB): 739kB downloaded
Running setup.py (path:/tmp/pip-build-148d257t/aiohttp/setup.py) egg_info for package aiohttp
Error compiling Cython file:
from .http_writer import HttpVersion, HttpVersion10, HttpVersion11, URL
from .http_parser import RawRequestMessage, RawResponseMessage, DeflateBuffer
from .streams import EMPTY_PAYLOAD, FlowControlStreamReader
cimport cython
from . cimport _cparser as cparser
aiohttp/_http_parser.pyx:22:0: 'aiohttp.' is not a valid module name
File "<string>", line 17, in <module>
File "/tmp/pip-build-148d257t/aiohttp/setup.py", line 27, in <module>
extensions = cythonize(extensions)
File "/usr/lib/python3/dist-packages/Cython/Build/Dependencies.py", line 840, in cythonize
cythonize_one(*args[1:])
File "/usr/lib/python3/dist-packages/Cython/Build/Dependencies.py", line 959, in cythonize_one
raise CompileError(None, pyx_file)
Cython.Compiler.Errors.CompileError: aiohttp/_http_parser.pyx
missing cimport in module '.': aiohttp/_http_parser.pyx
Compiling aiohttp/_websocket.pyx because it changed.
Compiling aiohttp/_http_parser.pyx because it changed.
Cythonizing aiohttp/_http_parser.pyx
Complete output from command python setup.py egg_info:
cimport cython
Cleaning up...
