Can anyone help with this error I’m getting when Home Assistant tries to start? This is occuring since trying to upgrade to the latest version with docker.
starting version 3.2.8
2020-03-10 15:57:17 ERROR (MainThread) [homeassistant.bootstrap] Unable to set up error log /config/home-assistant.log (access denied)
2020-03-10 15:57:17 INFO (MainThread) [homeassistant.bootstrap] Config directory: /config
2020-03-10 15:57:17 INFO (SyncWorker_0) [homeassistant.config] Upgrading configuration directory from 0.104.3 to 0.106.5
File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 350, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 342, in main
exit_code = asyncio.run(setup_and_run_hass(config_dir, args))
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 583, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 249, in setup_and_run_hass
safe_mode=args.safe_mode,
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 80, in async_setup_hass
await hass.async_add_executor_job(conf_util.process_ha_config_upgrade, hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 387, in process_ha_config_upgrade
with open(version_path, "wt") as outp:
OSError: [Errno 30] Read-only file system: '/config/.HA_VERSION'
