Hello everyone. I’m running into a problem upgrading from 0.82.1 to the latest. as far as i can tell, the upgrade goes perfectly fine.
Logs show no errors at all. But when I start the service, it doesnt fully start up. There is also nothing in the log. Below is the status of the service.
Dec 09 23:59:07 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:07 INFO (MainThread) [homeassistant.setup] Setup of domain tuya took 0.9 seconds.
Dec 09 23:59:07 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:07 INFO (MainThread) [homeassistant.components.switch] Setting up switch.tuya
Dec 09 23:59:07 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:07 INFO (MainThread) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
Dec 09 23:59:07 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:07 INFO (SyncWorker_9) [homeassistant.util.package] Attempting install of gTTS-token==1.1.3
Dec 09 23:59:09 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:09 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 2.8 seconds.
Dec 09 23:59:09 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:09 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 5.0 seconds.
Dec 09 23:59:09 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:09 INFO (MainThread) [homeassistant.loader] Loaded sensor.zwave from homeassistant.components.sensor.zwave
Dec 09 23:59:09 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:09 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.zwave
Dec 09 23:59:09 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:09 INFO (MainThread) [homeassistant.loader] Loaded sensor.nest from homeassistant.components.sensor.nest
Dec 09 23:59:09 DietPi homeassistant-start.sh[2292]: 2018-12-09 23:59:09 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.nest
What are my troubleshooting options here?
Thank you!
J
