I am building a custom component to connect my HA instance to a DIY bluetooth low energy device I am developed.
For that, I use bluepy and require the latest version 1.3.0. When I set REQUIREMENTS to bluepy==1.3.0, the component does not get loaded and I get an error about configuration in HA.
When I only set REQUIREMENTS to bluepy without version, the component gets loaded but I end up in runtime errors as I use some functions that are only available in the 1.3.0 release.
I tried to upgrade (temporarily the package from within the docker container with pip install -U bluepy but this is what I get :
# pip3 install --upgrade bluepy
Collecting bluepy
Using cached https://files.pythonhosted.org/packages/27/91/6cfca10bee9862f93015413cf9e6a52c3081a71f1518963396a055128f8e/bluepy-1.3.0.tar.gz
Building wheels for collected packages: bluepy
Building wheel for bluepy (setup.py) ... error
Complete output from command /usr/local/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-7144a_77/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/pip-wheel-zgqsmxn2 --python-tag cp37:
running bdist_wheel
running build
running build_py
Working dir is /tmp/pip-install-7144a_77/bluepy
execute make -C ./bluepy clean
error: [Errno 2] No such file or directory: 'make': 'make'
Failed building wheel for bluepy
Running setup.py clean for bluepy
Failed to build bluepy
Installing collected packages: bluepy
Found existing installation: bluepy 1.1.4
Uninstalling bluepy-1.1.4:
Successfully uninstalled bluepy-1.1.4
Running setup.py install for bluepy ... error
Complete output from command /usr/local/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-7144a_77/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-kao38q8s/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
Rolling back uninstall of bluepy
Moving to /usr/local/bin/blescan
from /tmp/pip-uninstall-7r4d6a2m/blescan
Moving to /usr/local/bin/sensortag
from /tmp/pip-uninstall-7r4d6a2m/sensortag
Moving to /usr/local/bin/thingy52
from /tmp/pip-uninstall-7r4d6a2m/thingy52
Moving to /usr/local/lib/python3.7/site-packages/bluepy-1.1.4-py3.7.egg-info
from /usr/local/lib/python3.7/site-packages/~luepy-1.1.4-py3.7.egg-info
Moving to /usr/local/lib/python3.7/site-packages/bluepy/
Command "/usr/local/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-7144a_77/bluepy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-kao38q8s/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-7144a_77/bluepy/
When looking at the github repo, I only found bluepy to be a requirements for miflora, mitemp, decora and another climate component, none of which I am using. Is there a way to force the upgrade of the pip package (even manually if necessary) ?
