Upgrade to 0.39 - Slider to Lightning Bolt
Had some issues but was pointed to the release notes in another thread and used the tool it references to alter my configuration.yaml
Following that I had to change “customize:” under zwave to “device_config:” now almost everything is working perfectly.
I previously had an issue a few versions where my relay sliders turned to lightning bolts. After using the tool it removed my entries:
      customize:
        - entity_id: switch.arest_pin_two
          **assumed_state: false**
        - entity_id: switch.arest_pin_zero
Now I have lighting bolts again on these two relays.
Here’s what configuration.yaml looks like now:
      customize:
        switch.arest_pin_two:
          entity_picture: /local/relay.jpg
        switch.arest_pin_zero:
Adding assumed_state: false makes HA not start at all.
I got it. The switches are command line and for some reason I had to do it to both switches. I was just doing one at a time in the interest of not changing too much stuff.
For now I seem to have managed the update to 0.39.0 :slight_smile:
