So I upgraded to 105.2 and stupidly didn’t read the breaking changes section about zones requiring names - home assistant wouldn’t launch. However, I had a recent snapshot so rather than trying to fix my broken upgrade I figured I’d just restore the snapshot and be on my merry way.
However, after snapshot restore home assistant STILL won’t launch .Here’s the error according to home-assistant.log:
config $ cat home-assistant.log
2020-02-07 06:46:00 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-07 06:46:01 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=30 from 2020-02-07 11:44:05.340346)
2020-02-07 06:46:08 WARNING (SyncWorker_19) [homeassistant.components.influxdb] Database host is not accessible due to '('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))', please check your entries in the configuration file (host, port, etc.) and verify that the database exists and is READ/WRITE. Retrying again in 60 seconds.
2020-02-07 06:46:13 ERROR (MainThread) [homeassistant.setup] Error during setup of component hassio
File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
return loop.run_until_complete(main)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 583, in run_until_complete
return future.result()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 249, in setup_and_run_hass
safe_mode=args.safe_mode,
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 89, in async_setup_hass
await async_from_config_dict(config_dict, hass)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 132, in async_from_config_dict
await _async_set_up_integrations(hass, config)
File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 377, in _async_set_up_integrations
*(async_setup_component(hass, domain, config) for domain in domains_to_load)
File "/usr/src/homeassistant/homeassistant/setup.py", line 49, in async_setup_component
return await task # type: ignore
File "/usr/src/homeassistant/homeassistant/setup.py", line 128, in _async_setup_component
await async_process_deps_reqs(hass, config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 290, in async_process_deps_reqs
hass, integration.domain
File "/usr/src/homeassistant/homeassistant/requirements.py", line 55, in async_get_integration_with_requirements
hass, integration.domain, integration.requirements
File "/usr/src/homeassistant/homeassistant/requirements.py", line 99, in async_process_requirements
if pkg_util.is_installed(req):
File "/usr/src/homeassistant/homeassistant/util/package.py", line 44, in is_installed
return version(req.project_name) in req
File "/usr/local/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3138, in __contains__
return self.specifier.contains(item, prereleases=True)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
item = parse(item)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
return Version(version)
File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
match = self._regex.search(version)
TypeError: expected string or bytes-like object
File "/usr/src/homeassistant/homeassistant/setup.py", line 170, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 159, in async_setup
if not await hassio.is_connected():
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 31, in _wrapper
data = await funct(*argv, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 161, in send_command
headers={X_HASSIO: os.environ.get("HASSIO_TOKEN", "")},
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 483, in _request
timeout=real_timeout
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 523, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 859, in _create_connection
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 967, in _create_direct_connection
traces=traces), loop=self._loop)
concurrent.futures._base.CancelledError
2020-02-07 06:46:13 ERROR (MainThread) [homeassistant.setup] Error during setup of component default_config
item = parse(item)
File "/usr/src/homeassistant/homeassistant/components/default_config/__init__.py", line 17, in async_setup
return await async_setup_component(hass, "stream", config)
2020-02-07 06:46:13 ERROR (SyncWorker_10) [concurrent.futures] exception calling callback for <Future at 0xb5321f50 state=finished returned Chromecast>
File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 324, in _invoke_callbacks
callback(self)
File "/usr/local/lib/python3.7/asyncio/futures.py", line 365, in _call_set_state
dest_loop.call_soon_threadsafe(_set_state, destination, source)
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 732, in call_soon_threadsafe
self._check_closed()
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 479, in _check_closed
raise RuntimeError('Event loop is closed')
RuntimeError: Event loop is closed
2020-02-07 06:46:13 ERROR (SyncWorker_19) [concurrent.futures] exception calling callback for <Future at 0xb4fd2210 state=finished returned Chromecast>
callback(self)
I’ve tried restoring from snapshot multiple times and deleting home-assistant_v2.db. Neither works. A CLI check of the config seems to tell me it’s fine.
