I’m running HA Core 2023.2 and mysql 8.0.32 on Ubuntu 18.04LTS.
I upgraded to 2023.2.0 and saw the notification message, “Database upgrade in progress” and thought nothing of it. On Feb. 2nd and Feb 4th when the updates came out, I upgraded and noticed that the same notification came up.
It’s been a few days now and I still see HA and mysql using a great deal of cpu time on my server.
Does anyone know if there is a way to check if this upgrade is stuck or progressing? I’ve restarted my HA instance a few times now. Do y’all think that the db upgrade could be completely messed up?
Suggestions on what I can do besides dumping the database and starting with a fresh on?
125G… and I thought my table was large (28G) …Anyway the upgrade took ages to run (I let it go over night) but it did finish. I queried the db for active queries to keep an eye on it. My db though is PostgreSQL.
I ran watch "mysql -e 'SHOW FULL PROCESSLIST\G'" I see output like the below. Is it normal to see: Info: ROLLBACK
**************************************************** - first update - ***********************************************************************
db: ha
Command: Sleep
Time: 0
State:
Info: NULL
Progress: 0.000
******************************************** - next update after 2 seconds - ****************************************************************
db: ha
Command: Query
Time: 0
State: Searching rows for update
Info: UPDATE events set time_fired_ts=IF(time_fired is NULL,0,UNIX_TIMESTAMP(CONVERT_TZ(time_fired,'+00:00',@@global.time_zone))) where time_fired_ts is NULL LIMIT 250000
Progress: 0.000
db: ha
Command: Query
Time: 0
State: Writing to net
Info: ROLLBACK
Progress: 0.000
db: ha
Command: Query
Time: 0
State: starting
Info: COMMIT
Progress: 0.000
db: ha
Command: Query
Time: 0
State: Updating
Progress: 0.000
db: ha
Command: Query
Time: 0
State: NULL
Progress: 0.000
db: ha
Command: Query
Time: 0
Info: ROLLBACK
Progress: 0.000
HA and MariaDB with small working (hass) database.
Everything works great before upgrading to 2023-2-0 to 3.
The upgrade converts the database from last_updated (DATIME) to last_updated_ts (DOUBLE) and sets last_updated to NULL. MariaDB cannot handle DOUBLE as DATETIME.
Does anyone have any suggestions on how this can be resolved.
@Prem Would you consider this a bug? I think you might be able to explain it better than I can. Perhaps you could open an issue on github so the developers see it?
