My current version is 2023.08.1 but I got this error during the upgrade.
Error:
- [281472198999488] Error updating Home Assistant Supervisor: Update of Supervisor failed: Can’t install ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.3: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.3/json: Not Found (“no such image: ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.3: No such image: ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.3”)
- [281472395922496] Error updating Home Assistant Supervisor: Update of Supervisor failed: Can’t install ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.08.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error (“Get “https://ghcr.io/v2/”: dial tcp: lookup ghcr.io: device or resource busy”)
- [281472447007296] Error updating Home Assistant Supervisor: Update of Supervisor failed: Can’t install ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.08.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error (“Head “https://ghcr.io/v2/home-assistant/aarch64-hassio-supervisor/manifests/2023.08.3”: Get “https://ghcr.io/token?scope=repository%3Ahome-assistant%2Faarch64-hassio-supervisor%3Apull&service=ghcr.io”: dial tcp: lookup ghcr.io: device or resource busy”)
- [281472168352192] Error updating Home Assistant Supervisor: Update of Supervisor failed: Can’t install ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.08.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error (“Get “https://ghcr.io/v2/”: dial tcp: lookup ghcr.io: device or resource busy”)
- [281472167516480] Error updating Home Assistant Supervisor: Update of Supervisor failed: Can’t install ghcr.io/home-assistant/aarch64-hassio-supervisor:2023.08.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.08.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error (“Head “https://ghcr.io/v2/home-assistant/aarch64-hassio-supervisor/manifests/2023.08.3”: Get “https://ghcr.io/token?scope=repository%3Ahome-assistant%2Faarch64-hassio-supervisor%3Apull&service=ghcr.io”: dial tcp: lookup ghcr.io: device or resource busy”)
