Hey there HA folks,
How can I safely migrate my installation and everything onto a fresh 4TiB NVME drive? The last time I tried to restore from a back up it did not work and I had to wipe everything and start fresh.
I currently have HaOS installed on a 256gb NVME. There is also a 1GiB SSD in the box. FriGate is running as an Add-On and I kept running out of space so I used the ‘move to data disk’ option in the UI.
So in the ideal set up, I would be able to keep HaOS on either the 1TiB SSD and ‘data’ on the 4TiB or just keep it all on the 4TiB. What do you recommend set up wise and what’s the best way to accomplish based on your recommendation?
