UPNP wont stop discovering everything; I can't disable it!
My HA is going nuts with upnp, and discovering everything and filling up my integrations page with entities that I keep ignoring. I am trying to disable it entirely, or certain integrations from being discovered; so that these ignored items do not re-appear at all.
discovery:
  ignore:
    - <integration>
Adding this line into my configuration is erroring out, as I am using integrations not listed on the discovery: documentation.
  • samsung_tv
  • onhub
  • idg
These are all failing with this error:
Invalid config for [discovery]: value is not allowed @ data['discovery']['ignore'][0]. Got 'samsung_tv'. (See /config/configuration.yaml, line 10).
In this instance, I am using samsung_tv; even though I found this in other forums back in 2019; it appears to have been deprecated; although I am still not sure how to actually ignore these.
So, if an integration is getting auto-discovered, and it is NOT listed on the discovery: documentation, then how can I disable it from getting seen and loaded in?
Discovery Documentation: https://www.home-assistant.io/integrations/discovery/
Do you have anything that you want discovered ? If not, disable discovery.
in 0.110.0 version and afterwards it can be ignored through integration interface
if you are in an earlier version you can use the following
discovery:
  ignore:
    - igd
I don’t believe so; I don’t have anything explicity enabled.
I do use a google_wifi sensor; but that is explicitly defined in my config; and working elsewhere.
I am running 110.2 (update to 110.3 available); and still receive this error:
Invalid config for [discovery]: value is not allowed @ data['discovery']['ignore'][0]. Got 'idg'. (See /config/configuration.yaml, line 10)
idg is also not listed on the Discovery docs, either, which might be why it’s failing.
If you have default_config: in your configuration.yaml, comment it out, and add everything manual from this page :
except SSDP and zeroconf
Is this standard practice? As I have NOT commented that line out.
No, it is not. But not having SSDP and zeroconf effectively disables discovery. But these are added by using default_config:
because you spelled igd wrong.
Fair enough; I will attempt to use this as the solution to my issues. Surprised there isn’t a better way to just disable discovery.
Appreciate the idea! :slight_smile:
That does the same thing:
Invalid config for [discovery]: value is not allowed @ data['discovery']['ignore'][0]. Got 'igd'. (See /config/configuration.yaml, line 10).
