Uptime Kuma Installs but dashboard page refused to connect. On second time to open
any thought
dashboard page 192.168.86.77 refused to connect. refused to connect. On second time to open
some log files
Welcome to Uptime Kuma
Your Node.js version: 22.16.0
2026-01-28T00:32:34-05:00 [SERVER] INFO: Env: production
2026-01-28T00:32:58-05:00 [SERVER] INFO: Uptime Kuma Version: 2.0.1
2026-01-28T00:32:59-05:00 [SERVER] INFO: Loading modules
2026-01-28T00:33:47-05:00 [SERVER] INFO: Creating express and socket.io instance
2026-01-28T00:33:47-05:00 [SERVER] INFO: Server Type: HTTP
2026-01-28T00:33:50-05:00 [SERVER] INFO: Data Dir: /data/
2026-01-28T00:33:50-05:00 [DB] INFO: Database Type: sqlite
2026-01-28T00:33:52-05:00 [SERVER] INFO: Connected to the database
2026-01-28T00:33:54-05:00 [SERVER] INFO: Listening on 3001
[00:33:55] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
2026-01-28T00:34:10-05:00 [UPDATE-CHECKER] INFO: Failed to check for new versions
[00:35:13] INFO: Service Uptime Kuma exited with code 256 (by signal 9)
[00:35:14] INFO: Starting Uptime Kuma...
2026-01-28T00:35:21-05:00 [SERVER] INFO: Env: production
2026-01-28T00:35:47-05:00 [SERVER] INFO: Uptime Kuma Version: 2.0.1
2026-01-28T00:35:49-05:00 [SERVER] INFO: Loading modules
2026-01-28T00:36:09-05:00 [SERVER] INFO: Creating express and socket.io instance
2026-01-28T00:36:11-05:00 [SERVER] INFO: Server Type: HTTP
2026-01-28T00:36:16-05:00 [SERVER] INFO: Data Dir: /data/
2026-01-28T00:36:17-05:00 [DB] INFO: Database Type: sqlite
2026-01-28T00:36:33-05:00 [SERVER] INFO: Connected to the database
2026-01-28T00:37:05-05:00 [SERVER] INFO: Listening on 3001
2026-01-28T00:38:48-05:00 [MONITOR] WARN: Monitor #1 'MPO': Failing: | Interval: 60 seconds | Type: http | Down Count: 0 | Resend Interval: 0
[00:41:23] INFO: Service Uptime Kuma exited with code 256 (by signal 9)
[00:41:27] INFO: Starting Uptime Kuma...
2026-01-28T00:41:53-05:00 [SERVER] INFO: Env: production
2026-01-28T00:43:14-05:00 [SERVER] INFO: Uptime Kuma Version: 2.0.1
2026-01-28T00:43:15-05:00 [SERVER] INFO: Loading modules
2026-01-28T00:43:34-05:00 [SERVER] INFO: Creating express and socket.io instance
2026-01-28T00:43:34-05:00 [SERVER] INFO: Server Type: HTTP```
