Uptime Kuma - mqtt check up doesn`t work
Hey
trying to get my mqtt Server running in Kuma but it doesn`t work.
Is there any special need in the Settings?
mqtt Server
password
port
MQTT Thema
mqtt Thema is any Topic on my mqtt Server - right?
For my test right now “espresense”
Greetings
I’m not much help, as I’m having issues as well. I have the following in setup, but getting “offline” trying to check the status of my zigbee2mqtt addon:
Any news here?
I’m also had this issue, from logs i can only see
2023-01-13T15:50:36+01:00 [MONITOR] WARN: Monitor #6 'WMBusMeters': Failing: Timeout | Interval: 60 seconds | Type: mqtt | Down Count: 0 | Resend Interval: 0
But definietly messages are appearing on broker.
You could just use the TCP port 1883 to see if the server is up. The MQTT monitor is only to monitor a specific topic for a certain message. Not what I think you want to accomplish.
From the “Monitor Type” select “TCP Port” and it should work.
