I am having trouble enabling remote access to my HomeAssistant running on Raspberry Pi. I have the DuckDNS setup and according to the logs it looks like it pulls down a LetsEncrypt SSL key just fine. When I start to enable the http: section, it appears it boots up, but my urls are inaccessible, both internal and external. I tried leaving off the ip ban part (last 2 lines) and it still fails to work for me. What am I missing or where can I check to see what might be going wrong?
2 things:
Did you forward port 8123 in your router to 192.168.4.83 ? http://192.168.4.83:8123 will not work, it will have to be https://192.168.4.83:8123, and you will have to accept the invalid certificate.
Ok, I had read different things about this… Some people said port forwarding was no longer necessary with DuckDNS, but I can try that out and see what happens. Also, I was not aware that I need to connect over https on the internal url too. I have not seen any documentation stating that. I can try this out tomorrow.
This was it. I read some bad documentation apparently. I did the port forwarding which allowed my external URL to work. I then put the https on the internal url, which allowed that one to work as well. Thanks so much for pointing me in the right directions. Now I can use this anywhere and my wife can too.
