Found this usb hub that may interest others as well, I am unsure if there is an option to connect it to HA for some automation to turn an port off then on again i.e when a BT adapter needs to be power cycled to be re-detected in HA for devices connected through it to work properly.
If there are other models that folks have gotten to work this may be something to look into to play with, I may order one when I get the chance to see what options it has.
Currently I use an mbeat 7 port hub that has your standard power on and off buttons but using a switchbot for that would be moot unless its exclusive via the app on the phone when I need to cycle that adapter port lol.
