USB install: HAOS swap job running forever
I am trying to install HAOS 10 (Generic x86-64) using this image: haos_generic-x86-64-10.0.img.xz, but when I boot the USB drive I keep getting this message on kernel load:
[ *** ] A start job is running for HAOS swap (7min 18s / no limit)
The kernel does not load, it waits forever for the job to complete.
I tried with balena etcher and dd created USB drives but I got the same result. I also tried to add noresume bootloader parameter but without success.
Debian Live USB boots without any problem on the same system. The system consists of an ASRock J4125B-ITX with Intel Celeron J4125 CPU, 8GB of RAM and a 480GB SSD.
I would like to have HAOS installed on the SSD.
Are there any steps or prerequisites that I missed to install HAOS?
Thank you!
Will this PC be running Home Assistant only? (This is the only way I know to run HAOS). I don’t either need nor want to mess with virtual machines or docker images. (Yes, I know that HAOS is a Docker image, but the user does not have to manage it).
I have installed HAOS on a few mini-PCs including two Intel NUCs. What I do is to flash this image (Generic x86-64 - Home Assistant) directly on the SSD, then install it back into the NUC and- done.
Here is from my notes:
“The NUC image on the Home Assistant site is not bootable. Flash the image to your hdd/SSD directly. I used an M.2 USB adapter and flashed to the M.2 drive, and after reinstalling the M.2 into the NUC, Home Assistant boots.”
This guide might assist you. Adapt to fit your requirements.
Thank you! I flashed my SSD using a Debian live USB and balena etcher. I used HAOS 9.5 to avoid getting the same error.
But, does it boot now?
Yes, it does boot.
Is the HAOS distribution image not a bootable installer by design? I think I am having a similar issue where HAOS boots and runs from the USB but does not install into the computers media.
After a long wait I get the Home Assistant CLI. I was expecting something similar to an “Ubuntu Live USB” but maybe that’s not expected.
