Weird issue, wondering if anyone can help diagnose or provide an explanation for this.
Running HAOS 2024.6.2 on x86 box, with a few add-ons.
Shut down the host so I could put a smart plug to monitor the energy usage of the box.
Upon bringing the box back up, noticed none of my Zigbee devices were working (Conbee II stick, using deCONZ on a 10ft extension cable).
Add on keeps trying to restart, but failing with “ERROR: Device ‘/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2212600-if00’ does not exist in deCONZ (core_deconz).”
In HA Hardware section, the device is no longer appearing. My Zwave stick is still showing and functioning, but not the Conbee II.
Tried: Restarting HA, no change. Reboot host, no change. Restored from backup, no change. Shut down host and remove smart plug, no change. Unplug, replug USB Conbee II, no change.
Resolution: What actually worked, was removing the USB Conbee II and putting it into a different port (was previously in USB 2.0 port, moved to USB 3.0 port). Upon reboot, everything came back and the device ID remained the same in the Hardware section (which is also in the deCONZ config add-on).
It kinda seems like the USB port just died out of the blue? Could the addition of the smart plug caused this somehow?
Host box Home Assistant command line now shows the following when a monitor is plugged in:
ha> [ 490.560466] usb 2-1.5: device not accepting address 11, error -32
