USB ports when migrating
I’m going to migrate my RPi 5 installation to an M910q running Promox, but I’m wondering how the USB ports shake out. I assume there is no magic and you have to go into each integration and reassign the correct USB port?
yes. unless you created udev rules for device then it is a bit more seemless
Depends. If you used /dev/serial/by-id/xxx nothing needs to be changed. If you used /dev/ttyusbx, you will need to reassign.
It looks like I’m OK.
Sonoff Zigbee 3.0 USB Dong - /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_1c0a04888245ed119c27cf8f0a86e0b4-if00-port0, s/n: 1c0a04888245ed119c27cf8f0a86e0b4 - ITead - 10C4:EA60
FT232R USB UART - FT232R U - /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A10OQGEA-if00-port0, s/n: A10OQGEA - FTDI - 0403:6001
