Use 433 MHz chime as alarm
Because I use a Ring doorbeel nowadays , I have a 433MHz doorbell leftover.
Now I would like to use the chime as a kind of alarm. Is it possible to send a signal let it make some noise ?
I thought I had seen something like that but cannot find the command anymore .
You need something that can send rf codes, e.g a sonoff rf bridge, a rflink or a rfxcom
I have a rflink, use it to control light and get info from some sensors.
I am looking for the code or command to make the chime ring.
Just press the original doorbell button and catch the code
Thank you, we are halfway now I think :slight_smile: And what command do I use to send the code with ?
Once you have the code, add it to HA like a switch, maybe something like:
switch:
  - platform: rflink
    devices:
      <the_cached_code_here>:
Maybe you need also play with the signal_repetitions value:
switch:
  - platform: rflink
    devices:
        signal_repetitions: 7
Once you have it working in HA, you can use it in automations.
Thank you both, I am going to find something to catch the code.
If you have a rflink, the process to catch the code can be found here :
https://diyprojects.io/how-build-rflink-433mhz-radio-home-gateway-domoticz/
Did not test it yet, since I’m waiting for all parts to arrive.
