{% if trigger == "Video-Freeze" %} {% set video = "SnU6YUhSQdg" %} {% endif %}
{% if trigger == "Video-Spring" %} {% set video = "kAoLNs2xshU" %} {% endif%}
What I want to do is use the template code to determine the value of the video and then use that value in the media_content_id where there is currently the DX6SXrSDErY value . I know I could replace that with {{video}} if I can figure out how to include the template code.
alias: Start Video Automation When Tag Scanned description: "" trigger: - id: Video-Freeze platform: tag tag_id: 04-43-EB-01-74-05-03 - id: Video-DanceMonkey platform: tag tag_id: 04-43-C4-01-5B-05-03 - id: Video-Spring platform: tag tag_id: 04-43-D9-01-86-05-03 - id: Video-BabyShark platform: tag tag_id: 04-43-A1-01-40-05-03 condition: [] action: - service: light.turn_on data: {} target: device_id: 2c2698657b6541db250237cd73d24d08 - service: select.select_option data: option: "{% set short = trigger.id.split('-')%}{{short[1]}} target: entity_id: select.wled_soundreactive_preset_2 device_id: - 2c2698657b6541db250237cd73d24d08 - b588b1ba6e337a04cc7b00e935bd4145 - service: media_player.play_media target: entity_id: - media_player.chromecast0324 data: media_content_type: cast media_content_id: " { \"app_name\": \"youtube\", \"media_id\": \"DX6SXrSDErY\" }"
The above works as is.
What I am trying to do is use one automation to call different effects.
The Tag IDs reflect the name of playlists and WLED effects. So you can see the code that stripes out the part of the tag_ids and uses it to call the playlists and WLED effects.
The last part with the chromecast is to play a video along with the WLED and laser lights. The problem is each YouTube video has it’s own media ID (that DX6SXrSDErY thing) so what I am attempting to do is select that media ID when the NFC is scanned by cross referencing the YouTUbe media ID with the NFC tag id.
Worse comes to worse I could each put each video play call into its own script and just call that but I was looking for a simpler more maintainable solution. The series of IF statements in the first post was my attempt to do the cross reference matrix but I don’t know how to “fit” it into the automation.
BTW this whole thing is going to be a experience room for by autistic grandson - he loves sounds, lights and videos
As with everything in HA are there a couple ways to do this. I would probably use trigger-attached variables… it puts adding, editing, or removing triggers and videos all in one place.
