Use Addressable LED Strips in Home Assistant Without the Usual Limitations
Hi everyone,
I wanted to share a small ESPHome project I built while experimenting with addressable LED strips in Home Assistant.
The core idea is simple:
A virtual light entity in Home Assistant controls a physical addressable LED strip running on an ESP device.
This allows the strip to behave like a normal Home Assistant light while keeping the actual LED logic on the ESP.
The current example implements a simple wipe on/off effect, but the real purpose of the project is the architecture behind it:
Home Assistant handles the control layer, while the ESP handles the LED execution layer.
That means the concept could later be extended with things like:
  • custom effects
  • segment logic
  • per-LED behavior
  • signal-driven LED control
Originally I also wanted to support configurable LED count and strip orientation from Home Assistant, but I could not get that part working cleanly with ESPHome.
So I’m publishing this as a community project in the hope that others might improve or extend it.
GitHub repository: GitHub - LKSkywalker85/ha-addressable-led-controller: Control addressable LED strips in Home Assistant like a normal light while keeping the LED logic on the ESP. · GitHub
I’d especially appreciate feedback from people with experience in ESPHome, addressable LEDs, or virtual entity architectures in Home Assistant.
